Linux Mint 17.1 Cinnamon x64
Windows 7 x64
Intel HD 3000
NVIDIA GTX 580m
Broken: Official 2.74 (Hash 000dfc0)
Worked: None that I know of
Node Editor - Material panel:
While nodes are changed in the Material panel, their previous node editor position is ignored, nodes jump to a new position next to a connected mix node; furthermore, while replacing more than one node connected to a mix node, both nodes jump to exactly the same position (on top of each other).
Open the attached blend (simple instructions are provided (only 2 steps to follow))
For those not wanting to use the blend, please see example screen captures below
While discussing Cycles node editor:
Wondered about this for a while. Adding a new Cycles material, nodes always appear off-centre in node editor space (upper right, instead of centralised), is there a design reason for this?
One area where this can be problematic; If the viewport is split and contains a small node editor window, 'new material' nodes can appear off-screen, as if nothing has been added.
Present behaviour (centre of node editor space highlighted)
Expected behaviour?
Zoomed and magnified view to help highlight the present 'new material' node placement
Above is not a complaint, (as mentioned) just something I've wondered about and not known where to ask until yesterday/today.
Thank you for your time,
David
