Happens on both Windows 10 and Windows 7
2.74 000dfc0
I imported an FBX file that came from Maya which worked fine aside from one small part of it. A certain small piece from the full model contained a part with anomalous shading where I am unable to bridge a flat face and make it appear flat.
After recalculating normals, making the whole mesh have flat shading, and removing edge shading (i.e. setting the mesh to smooth edges) it still occurs. No matter how I try to connect the front face (on both sides, including the one that isn't connected) either with n-gons, quads, or trianges, weird shading occurs.
I then exported this part of the model to an OBJ file,
. Interestingly, when imported into Blender, this OBJ file contains hard edges that weren't in the model I exported.After again removing the hard edges and setting the whole model to flat shading, the issue still persists like in the first image in this report. This means it's not an issue with the FBX importer because the anomaly is also contained in the OBJ file, or more likely, Blender's handling of it. Now, the model from this OBJ file can be exported to yet another OBJ file and it also contains the hard edges like in the second image in this report.
The issue can be fixed by clicking *Clear Custom Split Normals Data* under *Geometry Data* in the *Data* tab (the one with the triangle icon).
