Crash on render occurring when two hair modifiers are active that both use a UV mapped material for render
CPU: AMD A10-5800K APU with Radeon(tm) HD Graphics 3.80 GHz
RAM: 16384 MB
GFX: NVIDIA GeForce 660
OS: Windows 7 Home Premium 64-bit
Broken: 2.70a, 2.75a, 2.75.2
Worked: 2.69
When an object uses two hair modifiers, a crash on render may occur when both hair modifiers are active, and when both hair modifiers use a UV mapped texture (under the Render settings).
Changing the texture mapping from UV to Generated will prevent the crash.
Disabling one of the hair modifiers will prevent the crash.
Blend file:
  1. Render scene with default settings. Observe crash.
  2. To prevent the crash: Reload file, edit Ball Texture mapping and change Coordinates from UV to Generated. Observe no crash.
  3. To enable the crash: Edit Ball Texture mapping and change Coordinates from Generated to UV, rendering with this should cause a crash again.
  4. To prevent the crash: Navigate to the Particles window and disable hair2 to prevent it from rendering. Rendering with one hair modifier enabled, despite using a UV map, does not cause a crash.
