Rigid body joint spasms
working 2.74 -
not working 2.74.5 and 2.75
Rigid body jointed object goes insane.
I disabled the rigid body joint and the actor resumes normal behavior
https://www.youtube.com/watch?v=bHsHHC_eBUk&feature=youtu.be - testing in 2.74 vs ( 2.74.5 and 2.75)
http://youtu.be/PxeVphKK9CQ - isolated the rigid body joint as the issue. noted strange 'empty axis' that appears in the background?
Ok, so I thought about it,
I copied all the relevant logic that was in the previous rigid body into a new object, and deleted the old rigid body
fixed it,
so it's a issue with bringing in an older game object, and was not repeatable in 2.75 by creating new objects.
tried only deleting joint and adding new joint = no go
deleted rigid body object, then added new = fixed.
https://www.youtube.com/watch?v=Vohz5zUQtZw&feature=youtu.be
Angus Hollands (agoose77) lowered the priority of this task from Unbreak Now! to Normal.Jul 10 2015, 2:13 AM
Unbreak now is for pre-release show-stoppers.
I will keep that in mind
almost all my projects use at least one rigid body joint.
it was scary.....
Hi! @Jacob Merrill (blueprintrandom): Could you provide an ultra simplified .blend that shows the error beetween 2.74 and latest versions, please?
Porteries Tristan (panzergame) triaged this task as 30 priority.Aug 20 2015, 1:13 PM
@Jacob Merrill (blueprintrandom): you don't provide any test file for more than a month, so i close it as incomplete, reopen it when you will provide the test file.
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Aug 30 2015, 4:31 PM
No news since one week…
the problem was from moving a scene from a older version to a new version, and was fixed by deleting a rigid body, and adding one back.
as far as I can tell, I was the only one effected.
