Driver menu buttons are the wrong size on Retina Display
OS X Yosemite 10.10.2
MacBook Pro (Retina, 15-inch, Mid 2014)
Processor: 2.5GHz Intel Core i7
Memory: 16GB 1600 MHz DDR3
Graphics: Intel Iris Pro 1536 MB
Broken: 2.75a c27589e
On Retina Display (and probably all high-density display) machines the Graph Editor's Properties Panel, while in Drivers Mode, under the Drivers section is rendering two buttons at the wrong size. The "Update Dependencies" button and the "Remove Driver" buttons are too short to contain their text, so the text is overflowing and doesn't look right.
I am attaching a screen shot.
I don't know if there are other areas of Blender's interface that are affected. These two buttons are all I am aware of, but maybe it will become clear from looking at the code whether this is caused by something local to this one area of the UI or if other parts are affected as well.
  1. Be using a Retina Display machine
  2. Add a driver anywhere
  3. Open a Graph Editor window and select Drivers Mode
  4. Navigate to the Drivers section of the Properties Panel and observe
Seth L. (quantumanomaly) raised the priority of this task from to 90.
Seth L. (quantumanomaly) updated the task description. (Show Details)
Seth L. (quantumanomaly) edited a custom field.
Kévin Dietrich (kevindietrich) lowered the priority of this task from 90 to Normal.Jul 16 2015, 4:39 AM
Issue is that those buttons have hard-coded y values (22 and 18 pixels) which won't work with retina display.
