Blender quits without warning when trying to render with AMD OpenCL
I'm trying to render with GPU and when I click render it says "Loading Render Kernels (may take a few minutes the first time). Nothing happens for a few minutes, then all of a sudden Blender closes itself without any warning or error messages. The only thing that seems wrong is when I start blender, the cmd prompt window that opens before the program says "Failed to set 44100hz, got 48000hz instead". Could that be the problem, or is it something else?
Blender Version: 2.75a (hash: c27589e don't know if that's important)
System Info:
Dell Inspiron 15 3000 Series
OS: Windows 8.1 64 bit, x64-based processor
Processor: AMD A6-6310 APU with AMD Radeon R4 Graphics 1.80 GHz
RAM: 8GB
Hard Drive: 1TB
Austin Karl (murishani047) raised the priority of this task from to Normal.
Austin Karl (murishani047) updated the task description. (Show Details)
Austin Karl (murishani047) moved this task to Backlog on the Cycles board.
Austin Karl (murishani047) edited a custom field.
what version of the GPU drivers are you running ?
also afaik your card is not officially supported
Aaron Carlisle (Blendify) changed the task status from Unknown Status to Archived.Jul 28 2015, 5:32 PM
Aaron Carlisle (Blendify) claimed this task.
Just checked we only support Radeon 7xxx cards so nothing we can do if it crashes. Also the Failed to set 44100hz, got 48000hz instead is not a problem the message has to do with blender's sound system.
Ok thanks. I was wondering if that's what the problem was because it says the R4 is equivalent to 7470M and GCN-based so I didn't think it would be an issue. Guess it was. Thanks again!
