Memory leakage in Sequencer
Windows 7, GeForce
2.74a 64 bit, hash: c27589e
Blender memory consumption is not limited during playback in Sequencer or rendering using Sequencer.
Sorry for not applying a .blend file, but I think that it is not hard to reproduce.
I'm doing a video montage in Sequencer using a lot of video strips, some of them, of course, are just different cutted versions of one video file. The whole animation is about an hour long.
When I try to render my file the Blender crashes after consuming all of available memory. So I can render only ~5 minutes of my project at a time.
Also, there's the button in Sequencer named 'Refresh Sequencer', when I press it, sometimes the memory usage drops down to ~200 MB and sometimes Blender immediately crushes.
I have noticed that the most consuming case is when you have many frequently changing video strips.
Out of memory case log:
Calloc returns null: len=8294400 in imb_addrectImBuf, total 1360638192
Error: EXCEPTION_ACCESS_VIOLATION
'Refresh Sequencer' crash log:
WM_operator_last_properties_init: loading previous properties for 'SEQUENCER_OT_refresh_all'
   READ: strID=1 (VID: 0) dts=55951360 pts=55951360  KEY
   READ: strID=1 (VID: 0) dts=55952384 pts=55952384  KEY
   READ: strID=1 (VID: 0) dts=55953408 pts=55953408  KEY
 ->READ: strID=0 (VID: 0) dts=38063025 pts=38064026  KEY
... (and many more READs)
Sorry for not debugging it, I'll try to provide any possible information you ask.
Memory disparity image:
http://i.imgur.com/kb7Ff5t.png
MP4 files used:
Stream #0:0(eng), 15, 1/30000: Video: h264 (Main) (avc1 / 0x31637661), yuv420p, 1920x1080, 1/60000, 20304 kb/s, 29.97 fps, 29.97 tbr, 30k tbn, 60k tbc (default)
Stream #0:1(eng), 1, 1/44100: Audio: aac (mp4a / 0x6134706D), 44100 Hz, mono, fltp, 125 kb/s (default)
Real Name (uvx3) raised the priority of this task from to 90.
Real Name (uvx3) updated the task description. (Show Details)
Real Name (uvx3) added a project: BF Blender.
Real Name (uvx3) edited a custom field.
Real Name (uvx3) added a subscriber: Real Name (uvx3).
Also after rendering I have had a problem were memory is not freed afterwards
Sergey Sharybin (sergey) lowered the priority of this task from 90 to 30.Jul 28 2015, 12:24 PM
It is important to attach all files needed to reproduce the issue. Something which sounds obvious to you is not obvious for everyone. We're using sequencer on a daily basis here in the studio for Gooseberry edit and don't have memory leaks detected so far.
As for the crashes -- it'll help if you can isolate it a bit more. Crashes which happens sometimes to you are areally tricky to nail down from our side.
I've created a .blend file, which can help detect the error, I hope. It's in attached .7z archive. There's also some gdb output.
Thank you.
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Jul 28 2015, 6:37 PM
Sergey Sharybin (sergey) claimed this task.
Refresh Sequencer is not really thread-safe button, better not be used during rendering. Committed change which makes sure it's not used during rendering.
As for memory usage -- the memory is being used by FFmpeg context associated with each of the strip. It's possible to make them better memory managed by blender, but for now it's considered a TODO: http://wiki.blender.org/index.php/Dev:2.5/Source/Development/Todo/Editors#Video_Sequencer
So thanks for the report, but archiving it as a TODO now.
Sergey, thank you for making Blender :)
Maybe you can advise me some sort of solution to render my project? Now I render it by 3—5 minutes long pieces only. Is there some kind of 'pause render' possibility to safely free the memory during rendering?
You can have a script which modifies render range, invokes animation rendering for a shorter frame range, then clears the cache and continues rendering.
Second idea is to have pre-render hook which will free cache as well, but this wouldn't work in the current Git version because of the thread safety check added recently. Would need to re-consider the fix to keep that usecase working..
