Motion Blur in Cycles Prevents GPU from Flushing Memory
renderer: 'GeForce GTX 860M/PCIe/SSE2'
vendor: 'NVIDIA Corporation'
version: '4.5.0 NVIDIA 353.62'
PLUS
Device: #0
			Device Name: Intel(R) HD Graphics 4600
PLUS
Device: #1
			Device Name: Intel(R) Core(TM) i7-4710MQ CPU @ 2.50GHz
Running on Clevo W230SS with 16GB RAM.
Broken:
version 2.75 (sub 3), branch b'master', commit date b'2015-07-27' b'20:35', hash b'6df3e3a', b''
AND
version 2.75 (sub 0), branch b'master', commit date b'2015-07-07' b'14:56', hash b'c27589e', b''
As title. Same with every .blend and repeatable with this system config. Tracked memory usage with Afterburner, Blender requires a full restart to flush the GPU memory after attempting an animation or still image render with motion blur enabled.
Same as above--this happens with any .blend file here.
This now doesn't happen if I set all properties to default. I'll work through and find out which addon is causing the problem. Apologies guys!
Kévin Dietrich (kevindietrich) changed the task status from Unknown Status to Archived.Aug 5 2015, 1:47 PM
Alright, closing then.
Sergey Sharybin (sergey) changed the task status from Archived to Unknown Status.Aug 5 2015, 1:48 PM
You might have Persistent Data enabled in the performance panel. Some addon might be enabling it. Or it might be some other crap which happens in addon..
Anyway, if you'll find a way to reproduce the issue then we'll try our best to fix the issue! But for until you found exact circumstances needed to see the issue i'll move the report to archive. It's easy to re-open it anyway :)
