CPU: Intel Pentium Dual CPU T2390 @ 1.86GHz 1.87 GHz
RAM: 2048 MB
GFX: ATI/AMD Radeon Xpress 1250, 512 MB
OS: Windows 7 Ultimate, service pack 1
Drivers: ??
Blender: 2.75a (Official build from blender.org)
2.75a
As the title states, I cannot rotate or resize objects using the header (above the animation timeline). If I use "r" or "s", it works. But, I cannot resize objects using the squares on each axis.
- Open blender.
- Press the resize button above the animation timeline, and try to resize the cube (existing initially) using the 3 squares on the x, y, and z axes.
Expected behavior: I can resize using the squares.
Resulted behavior: The red circle with 4 black lines is selected instead.
Video: here.
I don't think I need to upload a .blend file because it concerns the cube that you get when you first open blender.
