Mac OSX 10.10.4; Intel Iris Pro 1536 MB
Broken: 2.75a c27589e
Whenever I go into camera fly mode by pressing shift + F, it allows me to move the camera with the WASD keys, but does not allow me to rotate it with the mouse. This only happens whenever I change the default layout in any way.
There is no file attached because this can be reproduced with a default blender scene.
- Open up blender
- Dismiss Splash Screen
- Go to the layout dropdown and change your layout to anything other than "Default"
- Hover over the 3D view and go into fly mode by pressing Shift + F.
- At this point, you can move the camera with the WASD keys, but mouse movement has no effect over camera's rotation...If you change your layout back to Default, and go into fly mode again, it works perfectly fine
This is the issue with the blender build stated above. Last time this was working was when I was in version 2.73 (did not test in 2.74). I also awn a Windows PC running Windows 10 and I don't seem to have this issue there.
Another way to repro the issue other than changing layout through the dropdown is to hover over the 3D view and press either the "N" or the "T" keys to bring/hide the menus on the sides....This also seems to cause problems
