Blender not working with windows 10
Windows 10
nvidia 720m 2gb
8gb ram
2.75a
after i had installed blender on Windows 10, I clicked the blender app, the console(window) that usually shows came up, the only word I was able to read was exceptions. then it closed and crashed. The blender app didnt load at all.
System info: http://www.pasteall.org/60558
adam (bounsir) raised the priority of this task from to 90.
adam (bounsir) updated the task description. (Show Details)
adam (bounsir) edited a custom field.
adam (bounsir) added a subscriber: adam (bounsir).
Julian Eisel (Severin) lowered the priority of this task from 90 to 30.Aug 14 2015, 5:43 PM
Crashes on startup can happen because of many reasons so let's check a few things:
  • Ensure both your OS and drivers are fully up-to-date
  • Ensure your GPU driver supports at least OpenGL 1.4
  • Ensure you have installed MSVC2013 redistributable package (http://www.microsoft.com/en-us/download/details.aspx?id=40784)
  • Try to disable any running antivirus
  • Ensure you have no python executable available in your %path% environment var
  • Try to re-download and re-install Blender
  • Try the latest build from our buildbot.
  • Try to start Blender in factory settings (--factory-startup commandline option) (this will show whether this is a userpref or addon issue or not).
  • Try to place this dll next to your blender.exe (software OGL, will be slow, but will show whether this is a driver issue or not).
Please never attach such info here directly, use a site like pasteall. Otherwise this ends up being a big wall of text :S
Do you happen to have an AMD processor ?
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Aug 24 2015, 2:31 PM
Sergey Sharybin (sergey) claimed this task.
5 days without reply. Archiving for until requested information is provided.
foreach ($list as $item) {
  work_miracles($item);
```I had the same problem. To solve it, run the blender in the integrated graphics mode.
goodluck
