Crash When Using Cycles
8x Intel(R) Core(TM) i7-3632QM CPU @ 2.20GHz
854x480 (Intel)
Broken: 2.75a c27589e
Whenever I try to use the Cycles Render engine, the entire application crashes.
  1. Click "Cycles Render"
Side Notes
This might have been something with the system, as Blender 2.75a was working previously. Re-installing it didn't fix the issue.
Apex (Apex) raised the priority of this task from to 90.
Apex (Apex) updated the task description. (Show Details)
Apex (Apex) added a project: Cycles.
Apex (Apex) edited a custom field.
Apex (Apex) added a subscriber: Apex (Apex).
Aaron Carlisle (Blendify) renamed this task from I found a bug to Crash When Using Cycles.Aug 17 2015, 12:05 AM
Aaron Carlisle (Blendify) removed Aaron Carlisle (Blendify) as the assignee of this task.
Aaron Carlisle (Blendify) lowered the priority of this task from 90 to 30.
Please:
  • Ensure both your OS and drivers are fully up-to-date. (Service Pack 1 is required for windows 7)
  • Ensure your GPU driver supports at least OpenGL 1.4.
  • Try to disable any running antivirus.
  • Try the latest build from our buildbot.
  • Try to start Blender in factory settings (--factory-startup command line option) (this will ensure whether this is a userpref or addon issue or not).
  • Try to tweak OGL settings in UserPreferences, System tab.
  • Try to tweak your GPU driver settings (e.g. try different values between 'performance' and 'quality' if you have such slider, etc.).
  • Attach here the report generated by Help -> System Info.
  • Launch Blender from the command line and attach here any error printed out in the console. (use --debug-cycles)
  • Try to place this dll next to your blender.exe (software OGL, will be slow, but will show whether this is a driver issue or not).
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Archived.Aug 24 2015, 7:54 AM
No information provided, closing.
