Properties Editor -> Material Tab -> Cycles auto renders icon which crashes blender when the material uses up too much ram
Windows 7 x64 GTX580, 16gb ram
Broken: 90f6675
Pretty much it is hard for artists to manipulate a objects material easily without the auto preview icon being fired off... Which poses a problem when dealing with large textures on low ram machines (look at the 42k resolution bugs I have been reporting :) )
  1. open up previously uploaded file F170781 on a low ram machine (12gb or 16gb should still crash)
  2. open up node editor whilst keeping the material tab open
  3. disconnect the image texture and reconnect
  4. CRASH!
Sergey Sharybin (sergey) changed the task status from Unknown Status to Unknown Status.Sep 3 2015, 11:15 AM
Sergey Sharybin (sergey) claimed this task.
If preview render is not possible, then final rendering is even likely to fail.. Surely it's always possible to improve memory usage or handle out-of-ram issues more gracefully, but wouldn't consider this a bug.
So thanks for the report, but considering it a TODO.
The problem lies that we tend not to have loads of high ram machines around... we tend to render off the ec2 which have the high amounts of ram... the artists still have to work on their low ram machines.
Understand that this isnt a big priority, just wanted flag it for the future.
It's more like a known problem which i've already tried to improve by avoiding having OIIO communication happening for previews.
Ideally, previews could share the same image pixels datablock, but in practice it's a bit tricky because Cycles might need to have different alignment than Blender is doing, plus user counter becomes more of a problem.
Also, out of memory can happen in other areas than texture loading. Additionally, OOM killer on linux can kill Blender before code itself will detect it run out of memory.
In any case, if you're building Blender yourself you might be interested to check D1502.
