win8.1 64bit | GTX680
Broken: 2.69 - 2.75a (so far)
I think there are some very strange behavior on the Create Orienation operator, though different between Object and Edit mode.
- Problem in Object Mode:
Select an object, then click the "+" button on Transform Orientation panel located in N sidebar. when uncheck the "Use after creation" button in F6 panel, the new created one is still used.
- Problems in Edit Mode:
- Same as above.
- Select a element then click the "+" button on Transform Orientation panel. Then try to name it, then rename it. you will see the renaming work will cause a duplication. What's more worse is that toggling any of the other three buttons below will also duplicate the existing one, and rename it like *.001,, *.002....
Btw... perhaps it would be better to capitalize the "Use after creation" as "Use After Creation", and "Overwrite previous" as "Overwrite Previous"? (not critical though...)
Thanks for checking.
