OS: windows 7 64bit, CPU: i5-3550 GPU: ATI HD7850
2.75a c27589e
I found these reoprts connected to this problem: T34094 D819 rBf770bc4757a2b471d5aaee048359096c1c79a6b2 (rB9489205c5c0b9b432d02be4a3d0d15fc62ee6cb9)
I found that it seems to be a particular range of angle between faces in wich the rays are able to miss the triangles.
Fireflies or worse are the consequences.
1.put the camera inside a cylinder (32 vertices)
2.rotate the cam so it is looking at the round part of the cylinder
- set the background shader strength to 5000
4.render it on 200 samples
It should show some fireflies all over the image.
File:
This problem occured to me on an extreme case as I built a sealing for a room.
I'll attach a simplified file of it:
btw. the "a" version of blender 2.75 has some problem with my GPU so I renderd with CPU.
