Hi there,
I want to notify an annoying problem when I'm using Blender on my laptop.
When I try to select a different object than the active one, the Blender ui turns crazy (see the attachment). After a few mouse moves, the program crashes and a segfault message is generated:
/usr/bin/blender: line 46: 13598 Segfault blender-bin $@
So, surprisingly, the only way to choose the different elements from the scene is via Outliner.
I know that there are many problems with mesa drivers supporting ATI Cards like Mobility Radeon IGP 350 (my graphic chipset). In any case, I've decided to report the problem.
I'm runing Blender under Ubuntu 6.06 on a HP nx9010 laptop.
Thanks for reading :)
Logged In: YES
user_id=103
Yeah, sorry to see this bad error... first of all you should really try one of the release candidates (check article on blender.org frontpage). Then you could try different drivers or settings for drivers.
In general, ATI cards can get to work with Blender pretty OK. (btw, try the official ATI linux drivers too)
Dentro del Sistema: SI
user_id=3015
The problem persists even with the latest RC3 release. Tried to install ati official drivers but doesn't want to work on my system (maybe ati doesn't support any longer those cards...)
Looking for other drivers... (DRI updates...).
Anyway, thanks for your time Ton.
