Short Description
blender.org/manual/render/blender_render/textures/index.html
needs to be cleaned up
Short Description
Could you define what needs to be done? (e.g. what pages should be moved where, or how the section should be re-done?)
well the procedural texture section there is no need for it too link to the sub-pages for each node. So basically the tree is two in depth for a lot of sections
And actually these textures AFAIK are the same for cycles so maybe all this information should be moved to a different location
They are not the same as cycles textures (BI and cycles have separate procedural textures), but I see what you mean about going too deep.
Is there any way to removing the links to the options and technical details for the procedural textures?
Never-mind the web version was not updated yet. It is rebuilt now and looks a lot better. You may want to add to the writing style to keep indexes shorter.
There already is a note to that effect here (more or less): http://blender.org/manual/about/markup_style_guide.html#table-of-contents
Thanks for the report :)
If you'd like any assistance getting the manual building, feel free to drop by the #blenderwiki IRC channel.
