Smooth shading attribute on mesh has no effect when selected on mesh with subdivision modifier on top of a skin modifier.
Duh: I completely missed the ´smooth shading' toggle in the skin modifier options :-(
Ubuntu 15.04 64bits/ Nvidia GTX970
Broken: 2.76 c586e30, same behaviour in 2.74 000dfc0
It is impossible to set the smooth shading attribute on a mesh that has a subdivision modifier on top of a akin modifier. Other combinations (for example a subdiv on top of a mirror modifier) work as expected. When clicking the smooth shading button multiple times on a mesh with either just the skin mod or with both, some changes in the apparent normals and geometry are visible that cycle with each click, but no smooth shading is visible.
Add -> Mesh -> Cube
Add Modifier : Skin
Add Modifier : Subdivision surface
Set Tools->Shading->Smooth
There is no effect,
Apply Skin Modifier
Now the smooth shading is applied.
Alternatively: load the attached .blend an click smooth shading: no smooth shading is applied, but clicking multiple times does change the modified mesh topology.
Michel Anders (varkenvarken) changed the task status from Unknown Status to Archived.Sep 27 2015, 2:07 PM
Michel Anders (varkenvarken) updated the task description. (Show Details)
