bone rotation
macintosh osx 10.7.5 \ AMD Radeon HD 6750M
Broken: 2.76 - e24ea81
Worked: 2.75 - c27589e
selecting bone tip and rotating doesn't move it.
1 - make armature with single bone
2 - enter edit mode. select head alone and rotate.
Predrag Lazic (particl3s) raised the priority of this task from to 90.
Predrag Lazic (particl3s) updated the task description. (Show Details)
Predrag Lazic (particl3s) edited a custom field.
Bone does not surely rotate even if I choose bone tail and rotate it.
version: 2.76 (sub 1), branch: master, commit date: 2015-09-29 23:58, hash: 491b189, type: Release
Bastien Montagne (mont29) lowered the priority of this task from 90 to 50.Sep 30 2015, 9:38 AM
Was introduced by rB291152e127e6cc4b60
@Bastien Montagne (mont29), are you sure about the revision? The one you mentioned here made change in code inside ifdef which is never being compiled in unless WITH_CYCLES_DEBUG is explicitly enabled in CMake config.
P.S. Actually nevermind. Bastien already gave correct hash. Were looking into same report at the same time :)
@Campbell Barton (campbellbarton) not sure what to do here… The old behavior is rather odd to begin with, rotation with only tip selected does not make much sense imho?
@Bastien Montagne (mont29). rotation with just tip selected was a quick way to rotate bone around it's head without switching to Individual Origins pivot point.
Assigning regressions project since technically it a regression in behavior since previous release.
Oki, then let's just make an exception here for rotation mode…
