Bone isn't affected by influence keyframe if the action is shared (*).
Confirmed, NormalPublicTO DO
(*) The complete tittle would be: "Bone isn't affected by influence keyframe if the same action is shared with another armature with bones with different names".
  • Open the file.
  • Move in timeline and see what the bone (armature "B") does with its constraint.
  • Select armature "C".
  • Move across the timeline in DopeSheet: bone of armature "B" isn't affected by influence keyframe
The channel of the armature "C" gets red underlined. So, the Action is affected of this "red-underlineness"... so, armature "B" is affected too.
I know that this is a kinky bug... it is not normal/suggested to use the same action in different armatures with different bones. I discovered this bug by doing that, by mistake.
Maybe it is not usefull to put time on fixing it, because it is not a normal configuration. You guys decide.
Mario Mey (mariomey) raised the priority of this task from to 90.
Mario Mey (mariomey) updated the task description. (Show Details)
Mario Mey (mariomey) edited a custom field.
Bastien Montagne (mont29) lowered the priority of this task from 90 to 50.Oct 2 2015, 12:17 PM
Have to summon @Joshua Leung (aligorith) here… Do we consider this as known limitation of current system, or is it really a bug? That 'fighting' between valid/invalid state in shared actions if not that nice, gives a bit non-predictable results.
This isn't really a solvable problem within the current design. Considering it a TODO for 2.8.
