If users want select node(s) on a frame, they usually have to select them one by one, because other selection tools, such as border select, lasso select, and circle select, will select the Fame node too, in which case, it has to be then removed from the current selection. IMHO, this is a behavior that worths improving a bit.
A short GIF to expose the problem:
