Windows 7 Home Premium X64 service pack 1
Intel i7 920 @ 2.67 Ghz
9 GB ram
Nvidia GeForce GTX 760 4 GB ram driver version 340.52 directX11
Broken: 2.75a c27589e date: 2015-07-07 14:56 and 2.76b f337fea date: 2015-11-03 10:56
Worked: 2.74 000dfc0 date: 2015-03-31 13:39
Proxy controls break when appending in scenes to new file
Steps
Attached zip file is a basic rigged prop consisting of 1 cube, an armature with one bone named ctl.god.c and a circle representing the bone shape. All in a group named grp.name
Preparation
- In a fresh blend file name a scene shot.001
- Link in the grp.name group from the zip file
- Create a proxy of ctl.god.c
- Create a second scene file with option "link object data". Call this scene shot.002
- Create a UV_sphere, select it and create a group called grp.ball
- You should now have a file with 2 scenes ( shots )and two groups. Both scenes have the cube rig linked in , shot.002 has a ball that is in grp.ball
- Save the file as test_master_shot_2.74.blend
( Old behavior ) Create a fresh file in blender 2.74
- Append in scene "shot.001" & "shot.002". This should bring in the group grp.name with the scenes.
- In shot.001 , grab the ctl.god.c control and move it in pose mode. The armature should work as expected. Hit control Z and it should go back to origin.
- Go to shot.002, Notice there is no grp.ball group. Group is missing from append ( This is a problem going back to version 2.74 at least )
( New Broken Behavior ) Create a fresh blend file in blender 2.75a or 2.76b
- Repeat previous append steps from version 2.74
- In these versions of blender you get a double of the proxy controls when you move the ctl.god.c control in pose mode
- Hitting control Z to undo movement completely breaks the control leaving two versions. This seems to be a problem with appended scenes
Also notice the grp.ball group is still missing from the appended file. It also doesn't seem to matter if you build the test_master_shot_2.74.blend file in 2.75a od 2.76b. It still breaks.
