Windows 7 Home Premium X64 service pack 1
Intel i7 920 @ 2.67 Ghz
9 GB ram
Nvidia GeForce GTX 760 4 GB ram driver version 340.52 directX11
Broken: 2.75a c27589e date: 2015-07-07 14:56 and 2.76b f337fea date: 2015-11-03 10:56
Worked: 2.74 000dfc0 date: 2015-03-31 13:39
Meta data stamp does not burn in using hardware render from the VSE editor
Add a scene strip to the vse editor
Turn on stamp output under meta data roll out in properties window. Check some sub options like time, date, ect.
In version 2.74 turning on the stamp option ( now renamed meta data ) would render scene info in hardware from the scene 3d window and in hardware from the vse editor. It would also render using the software rendering options.
In 2.75a and 2.76b turning on stamp output will only add a burn in using the hardware render from the 3d viewport and using the software render. It won't work using hardware render from the vse window if your trying to output a series of scene strips. I tried this with png, exr and mpeg movies and the result was the same. Turning on "show meta data" in the view option of the vse window gives the same result. No burn in.
