Windows 7 Pro SP1, NVIDIA GeForce GT 750M
Broken: 2.76 8c84a18 AMD64
Worked: don't know
When you add a boolean modifier to a mesh, let's call it A, and the modifier "Object" operand, let's call it B, is a child of the mesh itself (that is, B is child of A), the result of the modifier does not display in the viewport in the following two cases:
- When you first load the project.
- When you enter and then exit edit mode on child object B.
To have the modifier display, you have to either move the child or enter/exit edit mode on the parent or disable/enable the modifier, but when you enter/exit edit mode on the child again, the problem reappears.
- Load the attached .blend file, and you can see that the cube is not being "cut" by the child sphere, as it should.
- Press TAB (enter edit mode on the sphere) and the bool modifier starts displaying.
- Press TAB again (exit edit mode) and the bool modifier does not display anymore.
- Grab and move the child sphere, and the modifier starts displaying
- Press TAB twice (enter/exit edit mode on the sphere), and again the modifier does not display anymore.
