Snapping closest vertex with Pivot point set to Individual Origins
Win 10 64bit, GTX 970 (x2)
Broken: 2,76b official release
If you set Pivot point to Individual Origins and you try to snap the closest vertex it does not work - instead it always uses the Median Snap Target(or maybe Center - I am not sure). I am not completely sure if this is a bug but IMHO it should snap to closest vertex no matter what pivot point do I use.
  1. Open the attached blend
  2. In edit mode move the selected cube in x axis and try to snap it to a vertex of the other cube. It does not use the closest vertex but a median point instead.
  3. Solution: Change Pivot point to any other option and the snapping works as expected.
Marek Moravec (marek) raised the priority of this task from to 90.
Marek Moravec (marek) updated the task description. (Show Details)
Marek Moravec (marek) edited a custom field.
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 50.EditedNov 30 2015, 12:10 PM
Using the 'center' for snapping makes sense normally, but agree in this case its not ideal.
This is a general system though. So having exceptions needs to be handled carefully.
Possible fix, P295
@Germano Cavalcante (mano-wii) maybe you’ll be interested by this one? You’re our snapping expert now. ;)
I don't see the need to calculate islands when translating. I propose to skip the island detection in this case
Possible fix 2, P444
@Germano Cavalcante (mano-wii) Meh… don’t really have strong opinion here :/
I’d say, go by your solution, looks like it makes sense, and we can always revert and try something else if it creates other issues (pretty hard to predict what can cause what in that code).
Islands could be useful to identify the center of the groups when "Snap Target" is "Center" instead of "Closest".
But it does not work like that now and will not work that way after applying that "possible fix 2".
One solution to this case ( "Snap Target: Center") would be to preserve "island_info" (instead of freeing) and use its information to find the nearest center
