Rigid Body Final Mesh doesn´t behave correctly with boolean modifier and animations
OSX 10.11 intel core i5 Nvidia gtx 680mx
Happens also on Win32
Broken: 2.76b Tested also
When using animated meshes in conjunction with the boolean modifier. The rigido body system doesn´t behave as expected and doesn´t take into consideration the boolean modifier. This will be seen better in the example attached.
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Jan 8 2016, 7:57 PM
Thanks for the report, but here you are using an animated boolean, rigidbody does not support varying geometry at all… So no bug here, just unsuported feature.
