Transfer Weights options changed; manual does not reflect
Windows 10 NVIDIA
Broken: 2.76
Following advice of tutorials for previous versions, I saw that Transfer Weights options had changed; I checked the manual for my version (2.76), and it still listed the same options as the tutorials, but those options are not present in the program (specifically this page: https://www.blender.org/manual/painting_sculpting/painting/weight_paint/tools.html?highlight=transfer%20weights)
It says that the options "Group," "Method," and "Replace" are present, but they are not present in the software under "Transfer Weights."
Select 2 objects, one weighted.
Go to Weight Paint mode.
Click on Transfer Weights
  • compare interface with user manual -- the options do not match.
Robert Travis (hindemith) raised the priority of this task from to 90.
Robert Travis (hindemith) updated the task description. (Show Details)
Robert Travis (hindemith) edited a custom field.
Aaron Carlisle (Blendify) lowered the priority of this task from 90 to Normal.Jan 13 2016, 8:58 PM
I wonder a bit why it was assigned to me… This is doc work, change was noted in release notes when it happened (2.74 or 2.75 iirc). Will make quick edit to manual. :/
