OS: 64bit Lubuntu, kernel 4.2.0-23
CPU: AMD FX-8350 Octacore
GPU: GeForce GTX 650 Ti 2gb
Broken: 2.76b f337fea , 2.76-dev fea44ed
Worked: ?
Description of error
I have found that when rendering instances of hair-covered objects (in this case, a small park covered in grass), the BVH build time seemingly skyrockets compared to when non-instanced versions of those objects are copied. By "instanced", I am referring to empties set up as dupligroups.
For example, if I render two copies of the small grassy park (neither of them instanced), then I see a BVH build time of roughly 24 seconds in a quick test. But when I go to another scene and render to dupligroup copies of that small grassy park, the BVH build time is increased to a minute and 20 seconds.
During both tests, I was monitoring CPU usage. In the scene with the increased BVH build time, I saw that only one CPU core was being used during BVH build. This means that for some reason, the BVH build process is not taking advantage of multithreading when a scene contains hair-covered instance objects (and perhaps other types of instanced objects).
- Download and open the following .blend file:
- Switch the scene to Original and then render. Note the time for BVH build.
- Switch the scene to Instanced and then render. Note the increased time for BVH build.
