'transfer UV Maps' error
win7 64bit k2200
win7 64bit gtx970
Broken: hash:5cd3428
'transfer UV Maps' give me unexepted result
copy the the uv from "from" to "to" via 'ctrl+l >>> transfer uv map' the uvs looks like the same, but they are totally wrong if you check with checker map.
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Jan 29 2016, 3:49 PM
There is no bug here at all, you are trying to copy data between two meshes that are far from identical, this will never work.
You can try the 'Data Transfer' tool instead (ctrl-shift-T, UV option, choose 'Projected face interpolated' for both faces and face corners, and enable Auto Transform option), but it won't give you perfect result either.
thanks, I tried with data trasfer, following the topology and the uvs look like identicail in the uv editor, in viewport they look totally broken.
max
