Ubuntu 14.04 LTS 32-bit
Intel® Sandybridge Mobile x86/MMX/SSE2
Broken: 2.76b f337fea
Worked: 2.75a c27589e
The Particle UV in the Explode Modifier doesn't seem to work anymore
Set to Blender Render engine
Create a new Icosphere with subdivision: 4
Go to Object> Quick Effects> Quick Explode
A Particle System, Explode Modifier, 'Explode Fade' UV map, and 'Explode Fade' Material are created
The exploded pieces are supposed to fade over time by changing the Particle UV in the Explode Modifier (set as 'Explode Fade')
But for some reason the Particle UV isn't being changed
It still seems to work in older versions, so I'm guessing something has changed.
Any help is appreciated.
Thank you
