Cycles portals: Luminance artifacts
Win10 64bit, 2x GTX970, i7 5820K
Broken: 2.76b
Worked: ---
The portal planes divide the scene into smaller parts and some of the parts are rendered darker than the other.
Open the blend file and hit F12 (Render)
The render has visible "lines" going from the intersection of portals - even over the monkey.
Disable the second layer with portals and render it again - now the artifact are gone.
Marek Moravec (marek) raised the priority of this task from to 90.
Marek Moravec (marek) updated the task description. (Show Details)
Marek Moravec (marek) edited a custom field.
Lukas Stockner (lukasstockner97) lowered the priority of this task from 90 to Normal.Feb 16 2016, 11:35 PM
Can confirm the bug, most likely something in the PDF evaluation goes wrong when one of the portals is ignored due to the facing test.
I'll have a look.
