Object linked to scene, is not updated correctly in GroupInstance (objects with face users)
Win 7 64bit
Build from here: http://blenderartists.org/forum/showthread.php?392846-New-2-77-blender-bug-release!
Broken: 2.77 Testbuild 1
Worked: not sure if it ever worked ok.
Basically there is problem with deleting object from group using x-key.
lets say have cube object in group.
When I delete objects using X-key, it is not deleted from GroupInstance (meaning object is somehow still linked to group, I think). This happens only for object that are freshly linked to scene. See blend file below - with simple script for linking obj to scene.
short gif with bug
In attached blend file
I have two groups named 'Working' and 'NotWorking' each made of 2 cubes.
Also for each group I added one groupInstance object (shift+a->GroupInstance).
Cubes from working group (red color) are linked to scene and when I delete any of those cubes (x-key), they disappear from groupInstance - this is ok.
Now cubes from 'NotWorking' group (yellow) are not linked to scene, so you just run script from text editor, to link those 2 cubes to scene. When you now delete any of those cubes (x-key) the are gone from scene, but not from GroupInstances. Somehow those cubes are not deleted from group.
Jose Conseco (joseconseco) raised the priority of this task from to 90.
Jose Conseco (joseconseco) updated the task description. (Show Details)
Jose Conseco (joseconseco) edited a custom field.
The objects have fake users, print(bpy.data.objects['Cube.001'].use_fake_user)
IIRC there is no way to enable this via the UI, though it could have been done via Python. we could change this P324, though its not a very common open for objects.
Campbell Barton (campbellbarton) renamed this task from Object linked to scene, is not updated correctly in GroupInstance. to Object linked to scene, is not updated correctly in GroupInstance (objects with face users).Feb 19 2016, 4:47 AM
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 50.
Campbell Barton (campbellbarton) edited a custom field.
ah, ok. But then still even if I link obj to scene, and then do:
bpy.data.objects['Cube'].use_fake_user=False
And delete 'Cube' with X key, it is not deleted from group.
Now I just tested this on older blender builds (with fake_user=False), and:
  • deleting works ok on another PC -where no testbuild was installed (meaning object is deleted from group, when use_fake_user=False).
  • on PC where I installed testbuild 2.77 deletion won't work even on old builds. But I'm sure It worked before installing testbuild 1. So somehow testbuild broke my script even on older blender... Only using 'user_clear' on yellow cubes works-cubes are deleted permanently from group, but there was no need for this trick before testbuild.
ps. I think there is not need for UI for fake_users, because this is mostly usefull for python scripting.
I think I found the reason for buggy behavior.
Basically I blend file below we have red and yellow objects:
  • yellow object is member of 'NotWorking' group
  • red object is member of 'Working' group.
The only difference is - yellow object is linked to scene when script, from text editor, is executed (this time I set fake_users to False).
So in theory both yellow and red object should have 2 users (bpy.context.object.users): first user is group and second is scene. But red object has only single user, even though he is member of 'Working' group and scene (2 users).
I guess this is why deleting -bpy.ops.object.delete()- red object has different result, from deleting yellow object.
Maybe delete operator should force number of users to be 0 (bpy.context.object.user_clear()), so that object is deleted correctly from group too?
Blend file with slightly modified script (fake users set to false, and it prints number of users of red and yellow objects)
Group 'usage' is a 'USER_ONE' type, i.e. (to simplfy) it does not increase usercount, but it requires at least one user. So red cubes' usercount is (or rather, could be) OK, and yellows' one is too. But behavior of yellow cube deletion is broken.
There is no reason for an object to vanish from a group once it gets removed from a scene, this sounds like undesired side-effect behavior to me, typical of how Blender used to handle 'USER_ONE' case, in a very broken way. This is supposed to be fixed in 2.77 (but only when starting from clean sane state, older files already broken won't be fixed re IDs usercount).
Object shall be removed from group with group.objects.unlink method, just like with scene.
So to me, bug here is with those red cubes (you can easily reproduce same behavior with default cube, group it, instance that group, delete cube object, it gets removed from group - this shall not happen anymore). Will investigate.
Thanks for quick bug fix :)
However I liked how bpy.ops.object.delete() worked previously (unlinking from scene, and group at same time) :( . I mean for most applications, when user deletes something - it is gone. It was unexpected for me (and I'm sure for other users too), that after deleting object, it was still present as group member, that it why I reported it as bug.
So maybe those three operations could be split in future : unlinking from group, from scene, deletion (unlinking from everything). But I guess this should be reported as new task, right?
Yes, I see how previous behavior kinda looked OK… But imho it was not - e.g. if you linked a same object in several scenes, then what would you expect? that it gets removed from its groups only when you have deleted it from all scenes? that pressing X would immediately remove it from all scenes and groups altogether? Those are more like design decisions…
Point is, 2.77 fixes that inconsistency (we had similar ones with e.g. images when used by ImageEditor and texture, etc.), and now has a consistent behavior. If we want to also remove objects from their group when deleting them from all scenes, then this has to be implemented on the operator level. Think a lot of issues here also comes form the fact that user cannot actually manage object datablock itself (you only have access to it through its instantiations, either directly by scenes, or indirectly through groups). But that’s no bug. ;)
Yep, I totally agree this bug had to be fixed. But I was thinking about 'operator level' design change, as you described it. So the change would be:
  • change current bpy.ops.object.delete -> to bpy.ops.object.unlink (because this is what delete operator is currently doing)
  • bpy.ops.object.delete - would be new operator now -> completely deleting object from scene, groups etc. It would behave as delete operation in other apps,
  • bpy.ops.group.objects_remove(group='xxx') - no change here. This operator does what is says, unlike delete operator IMO.
English is not my native language, so maybe it wasn't clear, but this is what I was thinking about in previous post.
I have already overrode x-key with new 'real' delete operator in python, so I'm happy now :). But I'm thinking, that maybe you could implement this change in blender source code, so other users could benefit from it.
