addons with a dot in their dirname are not seen/discovered by blender
Win8.1 64bit | GTX680
Broken: 509270e
When installing addon via User Preference panel, it will fail when the zipped addon's root folder name contains dots ("."). Typically those downloaded directly from Github.
Leon Cheung (leon_cheung) raised the priority of this task from to 90.
Leon Cheung (leon_cheung) updated the task description. (Show Details)
Leon Cheung (leon_cheung) edited a custom field.
Bastien Montagne (mont29) lowered the priority of this task from 90 to 50.Mar 2 2016, 12:35 PM
It’s not installation that fails, it's finding such named addon. Blender simply does not find any addon which dir name has a dot somewhere, will check what happens here…
Bastien Montagne (mont29) renamed this task from Failed to install zipped addons to addons with a dot in their dirname are not seen/discovered by blender.Mar 2 2016, 12:44 PM
Issue comes from bpy.utils.path.module_names(), which assumes dirnames have no dot.
Fix is trivial, but not sure whether this behavior is intended (e.g. for optimizations of load time), so will let @Campbell Barton (campbellbarton) handle it. :)
Brendon Murphy (meta-androcto) lowered the priority of this task from 50 to Normal.Mar 5 2016, 5:16 AM
lower to normal priority
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Archived.Mar 16 2016, 2:12 AM
Python modules can't have dots in their name, so even if we change bpy.utils.path.module_names to support this, Python wont be able to import this.
Add-ons must follow naming rules of Python modules, this is documented here: https://www.blender.org/api/blender_python_api_current/info_tutorial_addon.html#install-the-addon
