Select Loop Inner-Region issue
Confirmed, NormalPublicTO DO
Win8 64bit | GTX680
Broken: 2.77 509270e
When working with face loop, this tool doesn't always work as expected.
Not sure if this can be a bug. Please check.
Leon Cheung (leon_cheung) raised the priority of this task from to 90.
Leon Cheung (leon_cheung) updated the task description. (Show Details)
Leon Cheung (leon_cheung) edited a custom field.
Because I think that it is a function to select faces in a domain closed by edges, I think that what use it in face select mode is not proper.
However, the behavior of it in face select mode does not seem to have validity.
sorry, my bad english.
mangostaniko added a comment.EditedMar 3 2016, 6:13 PM
As the operator description says "Select region of faces inside of a selected loop of edges" it currently does not work for loops of faces yet. Selecting an edge loop and then using Select Loop Inner-Region surely is just as comfortable.
It should work however? Maybe just do a region to loop which will yield two edge loops (speaking in loose terminology), and then loop to region again.
But i guess it might not be unambiguous, e.g. which of the edge loops should be used (can the longer one be assumed?) etc.
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 50.
Campbell Barton (campbellbarton) edited a custom field.
This can be supported, but wouldn't consider it a bug.
Oops, I see. Sorry for misreport... :)
Not sure I understand the problem. Can someone please elaborate?
