Mirroring objects breaks boolean modifier
Linux Arch - Nvidia GTX57
Broken: 2.76.0 f337fea, 2.76.11 da81227, 2.77.0 5513762
Worked: na.
After mirroring object (Ctrl+M) bollean modifier acts as if object has flipped normals.
Add two cubes to the scene, add boolean modifier (difference) to one of the cubes pointing another as target object. Use object mirror tool (Ctrl+M) on whichever of the cubes to trigger the bug. Normals are affected by mirroring operation causing boolean modifier to act as if mirrored cube has flipped normals. Reusing mirro fixes the problem (normals get flip back apparently).
bartus sz (bartus) raised the priority of this task from to 90.
bartus sz (bartus) updated the task description. (Show Details)
bartus sz (bartus) added a project: BF Blender.
bartus sz (bartus) edited a custom field.
Bastien Montagne (mont29) changed the task status from Unknown Status to Unknown Status.Mar 6 2016, 2:41 PM
Thanks for the report, but this is known issue - and internal to Carve library, so not worth fixing/working around it currently, let’s first see if bmesh booleans solve it.
