bm.from_object has parameters which don't work
Windows 10 64 bit
Nivida Quadro 600
Broken: 1776ad5
Changing the deform or render parameter for this function has no influence on the result:
https://www.blender.org/api/blender_python_api_2_77_0/bmesh.types.html#bmesh.types.BMesh.from_object
Open the .blend file, execute the script and look into the terminal. Both vectors should be different if everything is correct. Also both bmesh objects should use render deformation, which I turned off in the modifier stack. The modifier is used anyway.
I think that you should carry out the script of this file.
Sorry, my bad english.
