OSX 10.11.3 (El Capitan) Nvidia GTX 680m iMac Late 2012 Core i7 3.4Ghz, 32GB RRAM 1TB Fusion Drive
Broken: 2.77 22a2853
Worked: all versions prior to 2.77
Importing Obj files from another system that has absolute texture filename paths in it (e.g. C:\users\username\something.jpg) won't open in Blender. Get the following error since the path doesn't exist on OS X. In previous versions Blender would put in a default black texture and let me update th file paths via the editor. Now it refuses to import the files at all.
File "/Applications/blender.app/Contents/Resources/2.77/scripts/addons/io_scene_obj/__init__.py", line 147, in execute return import_obj.load(context, **keywords) File "/Applications/blender.app/Contents/Resources/2.77/scripts/addons/io_scene_obj/import_obj.py", line 1165, in load unique_material_images, use_image_search, float_func) File "/Applications/blender.app/Contents/Resources/2.77/scripts/addons/io_scene_obj/import_obj.py", line 401, in create_materials load_material_image(context_material, context_material_name, img_data, 'Ka') File "/Applications/blender.app/Contents/Resources/2.77/scripts/addons/io_scene_obj/import_obj.py", line 102, in load_material_image image = obj_image_load(imagepath, DIR, use_image_search, relpath) File "/Applications/blender.app/Contents/Resources/2.77/scripts/addons/io_scene_obj/import_obj.py", line 71, in obj_image_load return load_image(imagepath, DIR, recursive=recursive, place_holder=True, relpath=relpath) File "/Applications/blender.app/Contents/MacOS/../Resources/2.77/scripts/modules/bpy_extras/image_utils.py", line 199, in load_image return _image_load_placeholder(imagepath) File "/Applications/blender.app/Contents/MacOS/../Resources/2.77/scripts/modules/bpy_extras/image_utils.py", line 86, in _image_load_placeholder image = bpy.data.images.new(name, 128, 128)
TypeError: BlendDataImages.new(): error with argument 1, "name" - Function.name error assigning string, UnicodeEncodeError('utf-8' codec can't encode character '\udcc7' in position 0: surrogates not allowed)
This only happens when importing .obj files.
Steps to reproduce.
1.Unzip file with .obj in it.
2.Go to File > Import > Wavefront(.obj)
3.navigate to where the files location
- try to import object and you will get the error.
