2.77|Grease Pencil Sculpt buggy if strokes placed on "View"
Win7 x64 || AMD A10-7850K Radeon R7
Broken: 2.77 || 22a2853 (official 2.77)
Worked: (none)
If "Stroke Placement" is set to "View", sculpting a Grease Pencil stroke useing either "Twist" or "Randomize" has the stroke zip somewhere offscreen in the 3D-View.
  1. Open 2.77
  2. Go to the "Grease Pencil"-Tab in the toolbar, switch "Stroke Placement" from "Cursor" to "View".
  3. Draw a GP stroke in the 3D-View.
  4. Enter GP-Stroke-Editmode.
  5. Under "Sculpt Strokes" (toolbar), select either the "Twist", or the "Randomize" -brush (they both show the same, unexpected behaviour).
  6. Try sculpting your stroke.
  • What happens for me is, whatever part of the stoke I sculpt on goes haywire (zips somewhere offscreen, see pic.).
  • All other brushes work as expected, even when "Stroke Placement" is set to "View".
  • "Twist", as well as "Randomize" work just fine if "Stroke Placement" is set to anything other than "View".
The only info I could get from the 2.77 release notes was this (in the paragraph about the "Twist"-brush):
  • "Note: This currently doesn't work so well in 2D editors."
On BA, user YAFU confirmed the problem on his linux x64 system, (quote) "even in Blender downloaded today from Buildbot." (as of April 4th, 2016, GMT)
Thx., best regards, Uli
Ulrich Büch (kologe) raised the priority of this task from to 90.
Ulrich Büch (kologe) updated the task description. (Show Details)
Ulrich Büch (kologe) edited a custom field.
Looked into this, think the sculpt code should generalize 2D and 3D manipulation, so each brush doesn't need to handle coordinate conversion unless theres a very good reason to.
Otherwise this gets verbose and error prone.
Shouldn't be so hard to do.
Brecht Van Lommel (brecht) changed the task status from Unknown Status to Unknown Status.May 29 2019, 3:23 PM
Grease pencil sculpting in 2.8 is completely different, assuming this is no longer relevant.
