Import Obj file, missing Mouse icon for the import time
Windows 7 64 Bit home . nvidia 760 gtx . Driver 364.72 from 28.3.2016
Broken: (example: 2.69.7 4b206af, see splash screen)
2.77 Hash 4a64b36
When i import an Obj file then the mouse cursor turns into a black square with four numbers.
Reproduceable with Blender 2.76b too. Blender 2.75 and earlier does not show this behaviour.
Related Objects
Reiner Prokein (tiles) raised the priority of this task from to 90.
Reiner Prokein (tiles) updated the task description. (Show Details)
Reiner Prokein (tiles) edited a custom field.
Sergey Sharybin (sergey) lowered the priority of this task from 90 to 30.Apr 12 2016, 1:29 PM
Can not reproduce the issue.
Does it happen with factory startup?
Yes. For 2.77 it was the factory settings.
too fast at the send button ... and at my laptop, which is another Win 7 system. Means it is reproduceable at an independant system. It also happens with every obj file that i have tested. That was my first thought, that something is wrong with the obj file. But tested with several other files, and always same result.
Are you talking about cursor permanently becoming a square with numbers or only during import/export?
Not permanently. Just during import. Once done the cursor turns back to normal.
Have a look at the also attached video. It's short, but shows the issue much better than the image :)
@Bastien Montagne (mont29), is it an expected change to report progress of import/export?
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Apr 12 2016, 8:36 PM
This is standard progress cursor (since addons have no access to real progress bar from jobs)… you may not care about it for small files, but when you import 10Mb's .obj you could be happy to know import is actually ongoing, and not stalled somehow…
