Crash when deleting in edit mode
Ubuntu 14.04 64bit, NVidia Titan X
Windows 7 64bit
Broken: 2.77a (abf6f08)
When i try to delete vertices selected in attached file, Blender crashes. When I try to delete lower count of them, everything is fine.
  • open attached file
  • try to delete preselected vertices
Vaclav Cermak (disnel) raised the priority of this task from to 90.
Vaclav Cermak (disnel) updated the task description. (Show Details)
Vaclav Cermak (disnel) edited a custom field.
It is the same with 2.76 version.
And I experienced it on meshes imported with SHP importer: https://github.com/domlysz/BlenderGIS
There I filled another bug, don't know if it is related to this issue. Maybe SHP importer produces somewhat corrupted meshes? Blender shouldn't crash on them anyways, it should report some error ...
Campbell Barton (campbellbarton) changed the task status from Unknown Status to Archived.EditedApr 22 2016, 12:09 PM
Importers that don't ensure correct mesh data need to run validate(),
https://www.blender.org/api/blender_python_api_current/bpy.types.Mesh.html#bpy.types.Mesh.validate
This should be fixed in the add-on.
For a quick workaround exit edit-mode and run this in the Python console: C.object.data.validate()
