Tested in Windows 10, 7 and Mac OS 10.6.8
Broken: 2.77
Subsurf modifier does not trigger is_updated or is_updated_data on the active_object when changing render_levels.
Open default scene.
Add subsurf modifier to cube.
Run the script below.
Change the render_levels value for the subsurf.
Check output in the System Console.
import bpy
def track(scene):
if bpy.context.active_object.is_updated:
print ("Object is updated")
if bpy.context.active_object.is_updated_data:
print ("Object Data is updated")
bpy.app.handlers.scene_update_post.append(track)
