Shrinkwrap not taking auxiliary target into account properly
Windows 7 x64 GTX580
Broken: 999d5a6 onwards (including 11b0874)
Worked: b0a7e77
Shrinkwrap does not take auxiliary target into account properly
  1. Open attached blend file in the git version provided
  2. Notice it is going up into the air
  3. revert git backwards
  4. open attached blend file
  5. notice how it sticks to the plane below
Intel Core i7, 8 Gb RAM, AMD Radeon HD 7700
Windows 7 x64
Broken: 2.77 11b0874
Worked: 2.77a abf6f08
I can confirm there is a problem in latest builds and I have also found a couple of strange things:
  • If you enter Edit Mode on the bottom plane, shrinkwrap will start working.
  • It looks like that BOTTOM (Auxiliary) plane uses TOP (Target) plane’s dimensions as dimensions for shrinkwrapping! Changing the size of the top (Target) plane’s mesh seems to affect the bottom (Auxiliary) plane’s snapping for some reason.
You can take a look at my version of the test file, it's practically the same thing with planes, but some planes are changed to illustrate the issue I've found:
  • If you open my file in 2.77a, both small planes will shrinkwrap to both large planes.
  • If you open my file in latest build of 2.77, only closer one of the small planes will shrinkwrap to the bottom plane. Notice that closer plane does shrinkwrap because its top (Target) plane is bigger.
  • If you move the bottom (Auxiliary) plane left and right, you will also notice that far plane will eventually start shrinkwrapping too when bottom plane moves closer to its center.
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 50.May 30 2016, 3:00 PM
