A parented camera in fly mode moves it's parent.
Broken: 2.77.1 (3c64696), but also 2.77 release
A camera is parented to a cube. If you look through the camera and go into flymode with Shift+F, it will rotate not only the camera, but also the cube, even though the camera is the cube's child. Using rotate or trackball rotate on the camera behaves as expected, leaving the cube at its original position.
Open this file and press Shift+F in the left 3D viewport
you should disable Camera Parent Lock in preferences > interface
maybe should be off by default, seen this report many times
Bastien Montagne (mont29) changed the task status from Unknown Status to Archived.Jun 16 2016, 11:58 AM
Yep, totally desired default behavior setting, as said by @lower case (lowercase) this is configurable :)
