Significant slowdown when editing a mesh with shrinkwraps & slightly high poly
Windows 7 x64 gtx 580
Broken: 9c60043
Worked: ad6b7c0 (2.76)
Significant slowdown in terms of editing a mesh with shrinkwraps and slightly high poly
  1. open attached blend file in working git build
  2. notice how fast it is to edit the base mesh (just tab in and out)
  3. open attached blend file in broken git build
  4. notice how blender locks up when tryng to tab in and out
  5. force quit blender
  6. open attached blend file in broken git build
  7. delete all the middle planes which are shrinkwrapped to base mesh
  8. edit base mesh
  9. no lockup.
Carlo Andreacchio (candreacchio) raised the priority of this task from to 90.
Carlo Andreacchio (candreacchio) updated the task description. (Show Details)
Carlo Andreacchio (candreacchio) edited a custom field.
Forgot to attach file!
Found two closer builds to isolate where the slowdown occured:
1422f0d works fine
999d5a6 doesnt
Should clarify, it is not just tabbing in and out which is the problem but also manipulating the base mesh.
Campbell Barton (campbellbarton) lowered the priority of this task from 90 to 50.Jun 22 2016, 6:15 AM
Caused by rB0b5a0d84126e629394b198508789378eb5663561
Since this commit bvhtree_from_editmesh_looptri runs for every shrink wrap modifier evaluation.
Any chance there is a build with D2069 applied? would like to check it out and see if it fixes the problem
