Driver shows wrong value
Win7, Radeon HD4600
Broken: 2.77a
It seems to be visual error. After 130 frame (nearly) Driver shows incorrect value which he is copying at the moment.
Set driver for X rotation to copy values from Z rotation keyframes. Z-rotation is linear extrapolated in graph editor.
Kévin Dietrich (kevindietrich) changed the task status from Unknown Status to Archived.Jul 14 2016, 12:54 PM
The value is pretty much correct, it is just offset by -180, though quite obviously there is a dependency cycle here:
Dependency cycle detected:
  'Cube[Object].DRIVER(rotation_euler[0])' depends on 'Cube[Object].TRANSFORM_FINAL()' through '[Target -> Driver]'
  'Cube[Object].TRANSFORM_FINAL()' depends on 'Cube[Object].TRANSFORM_LOCAL()' through 'Object Transform'
  'Cube[Object].TRANSFORM_LOCAL()' depends on 'Cube[Object].DRIVER(rotation_euler[0])' through '[Driver -> Transform]'
Such cycles can, and do, affect the result of the dependency graph evaluation. (Also, the error only shows up every 2 frames here).
Unless the error can be reproduced without dependency issues, I'm gonna close this report, can be reopened otherwise.
