Ubuntu 16.04
Broken: All from 2.75a c27589e to 2.77a abf6f08
Working: 2.74 000dfc0
The feature Proxy Custom File is not working anymore. The proxy file is just ignored and it shows an scaled version of the input.
- Add a Movie strip to Sequencer
- Set Proxy/Timecode, Proxy Custom File and select another video as proxy
- Set 25% size to be used
- In View Settings of Image Preview window, set "Proxy render size" to 25%
- Proxy file is not used
Related Issues
I think it seems to be related with the introduction of the Per Project/Per Strip feature. A file saved with 2.77 and a Proxy Custom File added is not open correctly in 2.74 (before this feature). The option appears unchecked. T38806 was similar, but the new issue is not solved reopening the file.
.Blend with the issue
I believe this blend file has everything to show the issue. It includes a video file and a proxy video file with a grayscale filter, so you can make sure the proxy is not been used:
Screenshoots
Working in Blender 2.74:
Broken in Blender 2.77a:
