IvyGen addon doesn't launch from search
Windows 10 64bit, Nvidia Geforce GTX 750 Ti
Broken: 2.77a abf6f08, 2.76 48f7dd6, 2.60 r41226
Worked: I'm not sure when this worked
Running the IvyGen addon from the search menu does nothing.
Gif of issue
Setup:
  • Load the default file
  • Enable the IvyGen addon
  • Place the cursor on the side of the default cube
  • Select the cube
(Alternatively use this blend file)
Example of bug:
  • Press space to bring up the search menu
  • Type Ivy
  • Select IvyGen
  • Nothing happens
Work around (credit to JA12 on irc.freenode.net/blender for this):
  • Press Shift+A
  • Select curve
  • Select Add Ivy to Mesh
  • Ivy is generated
Brendon Murphy (meta-androcto) lowered the priority of this task from 90 to Normal.
All menus invoke the generator with operator.updateIvy = True, I propose adding an invoke method to do same
def invoke(self, context, event):
    self.updateIvy = True
    return self.execute(context)
Brendon Murphy (meta-androcto) changed the task status from Unknown Status to Resolved.Aug 12 2016, 3:06 AM
committed thanks @Peter Staples (batfinger)
closing as resolved
Thanks for the fix, I've confirmed it works both with the search and the Shift+A menu on 2.77 bac1279
