Win 7 64 Ult
GeForce GTX 580 1.5 GB
Broken: 50a44ed-win64
Worked: -
Alembic exported from 3ds Max 2016
If the exported alembic has an Empty (in 3ds Max called Point Helper), parent something to that helper, once you save a file and reOpen it - instant crash when you enable the layer where the Empty or the child object of that Empty is.
Note, you have to save the blend file and then reopen!
Edit:
After more testing, it seems that just adding another object to a new layer will make Blender crash, after saving and reopen, when the layer where the Emptys are is enabled
2 files are provided:
http://edge-loop.com/images/blender/bugtracker/alembicBug/alembic.blend
http://edge-loop.com/images/blender/bugtracker/alembicBug/alembic_crash.blend
alembic.blend:
- When you open alembic.blend, you are on Layer 2. and you can enable visibility on all layers without crashing.
- Layer 1 has the imported Alembic Emptys.
- Layer 2 has a cube created in Blender
alembic_crash.blend:
- In this file all I had done was add a Torus on Layer 11, and this was enough to create the crash.
- When you open alembic_crash.blend, you are on Layer 11. and you can enable visibility on Layer 2 without a crash. If you enable Layer 1, it will crash Blender.
- Layer 11 has a torus created in Blender
Let me know if you need more info.
