OS: Ubuntu Linux 16.04, kernel 4.4.0-34
GPU: EVGA GeForce GTX 950 FTW, driver 361.42
Broken: 2.77a abf6f08
When hair kink settings such as curl or wave are used with hair, and the emitting model is scaled, the hair becomes distorted. No change to the hair appearance occurs when kink is not being used (assuming the hair is combed, that is). The problem is likely because the kink is based on world scale instead of local or pose scale. This issue can be problematic for character models using kink, if those models are using scaling.
- Download and open the following .blend file:
- Observe the unscaled hair system
- Select the emitter sphere, then scale it down to about 0.1 scale.
- Zoom in and observe the distorted hair.
