multiview: overwrite and file naming
Confirmed, LowPublicKNOWN ISSUE
"not overwrite" option doesn't work with multiview when some views already exist on disk, could be a minor problem but rendering one single view with views option activated create a 0 byte "myfile_L.jpg" file but save only myfile.jpg
Sergey Sharybin (sergey) lowered the priority of this task from 90 to Normal.
@Dalai Felinto (dfelinto), something fun to investigate for you? :)
Dalai Felinto (dfelinto) triaged this task as 50 priority.Sep 28 2016, 3:59 PM
Confirmed, but ...
The code tries to query if either view is present before refusing to render. That happens because the "overwrite" code happens even prior to the rendering loop.
In your particular case why would you require rendering only of a single view?
Because
Trying to render 6 views doesn't work, cuda error (probably a bug)
or because I render on multiple computer
or because rendering two view take 2min 58 second versus 2x24 seconds for one view at a time (empty scene with high resolution background) (probably a bug)
or because I already rendered one view and I satisfied with the result
scene file attached
Jeroen Bakker (jbakker) triaged this task as Low priority.Jan 28 2020, 9:11 AM
Jeroen Bakker (jbakker) changed the subtype of this task from "Report" to "Known Issue".
Jeroen Bakker (jbakker) edited projects, added Render & Cycles; removed Tracker Curfew.
I mark this one as known issue as the code works as designed, but the design is lacking.
